OLE Object Text Issue
I am pasting a linked spreadsheet(MS Excel 2010) onto an ACDE drawing. I attached 2 screenshots, both are the exact same file, one is showing how the text shows up in ACADE(Bad Text.png) and the other in TrueViewer(Good Text.png). In ACADE the text comes out squished which it also plots this way, in TrueViewer the text displays as it does in Excel. I have searched through the settings and have not found a solution to this issue. Please can some one point out which setting is causing this.Good Text.pngBad Text.png
rhesusminus
Seems strange, but first I'd have a look at the different variables available for OLE:
Try to set the OLESTARTUP to 1, and see if it look better on the plot? OLEQUALITY is set to 3?
Also, check to see if some of these commands help:
Maybe OLERESET does something good?
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
Thanks for the reply, and sorry for my delayed response I have been incredibly busy so have not gotten back to this until now. Anyway, I tried altering the OLEStartup to the suggested setup and it did not have an effect on the drawing in CAD or on the plot. The OLEQuality is already at 3. I tried reset OLE and that also did not have an effect. I will try messing with the other settings you mentioned but if you have anything else that may help let me know.
