- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I would like to use the move attribute command, draw a window around 48 attributes, pick from the middle right of the first one and move (which all works up to this point) and snap onto a construction line. The snap onto the construction line doesn't work, it just doesn't show up.
It seems my choices are either do it by eye, or move each one (on 10 pages, so 480), the required distance manually, as you also can't select multiple attributes, move, and enter a value, either.
Any help on why the two above don't work?
