New Designer Using ACAD Electrical
Message 1 of 10
My company is looking at using AutoCAD Electrical for our electrical drafting.  One of my electrical designers is evaluating it right now and is basically telling us that the symbols are not standard and that the software is going to be difficult to use and that just using a block library would be better.  Is he right or is he just resistant to changing to new software?  I'm a civil designer so I don't know anything about electrical symbols.
Replies (9)
Message 2 of 10
TRLitsey
Hi there,
ACE is a powerful and versatile tool.  It would be over kill for very simplistic projects.  It is indispensable for large involved projects.  For example, if a project involves 15 components and the entire schematic can be drawn on one 8-1/2 x 11 piece of paper ACE is not going to increase your work flow a whole lot.  On the other had if your project involve 200 components and the schematic is 100 sheets of 11 x 17, ACE provides the tools to automatically maintain cross references, keeps track or components used and location, marries the components on a panel layout drawing to the components as shown in the schematic, so on and so on.  It really depends on what your deeds are.
You may want to read through the comments in this post, several different view and observation
Good luck
http://forums.autodesk.com/t5/autocad-electrical-forum/which-autodesk-product-is-right-for-me-buildi...
Please mark as a solution if this works for you, kudos are always welcome
Message 3 of 10
rhesusminus
Hi Evan!
If you install AutoCAD Electrical by pressing "Next, next, next, next..." you don't get all the symbol libraries installed. Just the US ones.
Go to control panel -> Programs and find AutoCAD ELectrical 2017. Press "change" to get back to the installers. Now you should be able to add the other (European?) symbol libraries and also component data from more manufacturers.
Make sure you open one of the demo projects for the symbol standard you use when testing.
Also, don't be afraid to ask questions here!
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Autodesk Expert Elite Alumni
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
Message 4 of 10
ccad2509
Definitely I fear change attitude
There is no comparison between vanilla AutoCAD and ACADE
Even though I bitch and complain on how bad ACADE is using plain AutoCAD for electrical design
Is one step up from using a drawing board
Message 5 of 10
jseefdrumr
This will all depend on what, exactly, your company does. ACADE lends itself well to schematic drawings and panel layouts, such as for industrial machinery, conveyor systems, etc. It is not meant for doing residential lighting layouts, PCB design, or testing/calculating/simulating circuits. ACADE keeps track of linked components, sharing catalog and other information across a project. It updates changes automatically, automatically generates terminal strips, offers reports on just about any scrap of data that it monitors, and like most ACAD-based products, also offers about a kizillion ways to customize, program, etc.
Also: If you're civil, and you're working with an electrical drafter, I can only assume you're either dealing in water/wastewater treatment, or some aspect of mining. If so, it could very well be that ACADE isn't a good fit for what you do. ( I did similar stuff in the civil field many moons ago)
As for your particular issue:
AutoCAD Electrical comes with several standard sets, each with its own symbol library. I would first insure that your designer is using the correct symbol set.
That being said, there is no actual 'official' standard in North America to which we must adhere. In Europe, things are usually governed by IEC standards. To that end, ACADE allows you to choose from the European standards, the antiquated, now-defunct JIC standard, and the NFPA-79 standard (which absorbed JIC decades ago, and which most people in the States use).
So when your designer says that the symbols aren't standard, I wonder what exactly he or she means. This is why I recommend checking the symbol set being used. (Changing it isn't hard, do a search on this forum to see how)
If this person is of the opinion that using a block library would be better, my assumption is that he/she resists change. Because while there IS a learning curve, ACADE is very competent and generally easy to use, for most things pertaining to electrical design for industrial applications. The tools and capabilities that it brings to the table make it better than using a basic cad program with some block libraries by far. It's just, drafting in ACADE isn't really like drafting in Vanilla ACAD -- you really can't use the commands you know, you have to learn the ones offered by Electrical. But IMHO, if you're anything like a decent ACAD drafter, the transition to ACADE isn't difficult at all, especially for someone who already has a background in electrical drafting.
Hope this helps,
Jim
Jim Seefeldt
Electrical Engineering Technician
Message 6 of 10
dougmcalexander
The symbols are from ANSI Y32.2 and IEC60617.  These symbols have been used to create tens of thousands of projects, if not more, with AutoCAD Electrical since the mid 1990s, when the program was marketed as Toolbox/WD, "Wiring Diagram".
I have been using and teaching the software since 1997 and I personally have thousands of projects designed using it.  I cannot imagine using it only as a symbol library.  I take advantage of he automation, such as auto-tagging of components and wires, automatic bill of materials and wire from/to list, automatic error checking, and more.  There are also automated functions to alleviate many of the mundane tasks you must perform with plain CAD, such as typing text for such things as rung numbers and function text, trimming lines/wires, just to name a couple.  The panel layout utilities provide a list of components from the schematic, cross-references the component part numbers in this list against a lookup database of footprints and allows you to insert panel footprints that are linked to the schematic equivalent symbols for perpetual bi-directional updates.
I am only scratching the surface.  But I must advise that proper training is paramount to getting the most from the software.  You can use the provided Helps to get started but learning the software piece by piece can waste valuable time.  It is best to attend instructor-led training somewhere, or bring the instructor to you. With just a 5-day training course you can be well on your way to becoming productive and efficient with the software. If you are in Europe I suggest that you contact Trond "Rhesusminus" for comprehensive training.  If you are in the U.S. I offer a comprehensive course that focus on the administrative side of the software as well as daily use.  I also offer phone and e-mail support.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor
Specializing in AutoCAD Electrical Implementation Support
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Message 7 of 10
jseefdrumr
Gotta +1 Doug, training is super-important. I work in a small company that can't afford to send one lonely Electrical Drafter (me) to training. As a result, I spend a lot of time on these forums just trying to stay up-to-speed and to learn how to make my work easier. Even though I've been on this software for a year and a half now, I'd still jump at the chance at training just to fill in all of the holes that you get when you have to educate yourself. if your company makes the move to ACADE, and y'all can afford it, get some training in there somewhere.
I also have to +1 Trond, who encouraged you to post if you have questions. This is the best one of all of Autodesk's forums I've ever used, bar none, it's the best, most helpful community.
Jim Seefeldt
Message 8 of 10
Thanks for the input everyone.  We are a small company that services the mining industry.  Most of our electrical work would be schematics and wiring diagrams for equipment.
I suspect that my guy is just resistant to change.  We have the software as part of a larger package, so we aren't paying extra for it specifically, but since we have it I think we should be using it.
I'll look into getting him some training, maybe see if there are some tutorials online or manuals that are available for purchase.  In classroom training tends to be pretty expensive.
Message 9 of 10
jseefdrumr
It sounds like ACADE would be a good fit for you, then. My company (also small) mainly designs equipment to support the bourbon industry. And while the benefits of training trump all, don't feel like it's a necessity for this software. My company hired me knowing I had no experience with ACADE, and they gave me three weeks to get myself up to speed. (Basically, they paid me to train myself.) I consider myself a fairly competent CAD operator, and this was really a challenge. So, it's possible to operate ACADE without formal training. I do OK without it, though every few months I found out something I'm doing could be done better. However, you've got to be A) willing to learn new things, and B) able to figure things out on your own. IOW, ACADE may fit your company, more than it suits your personnel. Good luck.
Jim Seefeldt
Message 10 of 10
shuhn
I was resistant to using the software as well, but, after 10+ years, I couldn't imagine going back to using plain ole vanilla AutoCAD.  There are a few customers of ours that require us to use their print format, basically, copying sections/pages of prints, and massaging them to reflect what we're building.  This is a nightmare, and there is so much more work to do it this way.  I would imagine there would be several reasons to reject the software, one of which would be protecting yourself from being more productive and the downfalls thereof, and the other could be pure laziness on the idea of learning how to use the software.
Imagine if all the mundane busy work in your prints just went away, and not having to manually draw everything every time.  I'm not as eloquent in describing the difference, but there are so many tools in ACE that cannot be duplicated in plain vanilla AutoCAD.
To be fair, I have worked with AutoCAD in several different flavors for over 20 years now, and I have been working with ACE for over 10 years now, and have had a good bit of training, including a week with Doug McAlexander for the Admin-Level training he provides.  I have modified the stock symbols, created my own, made them work with some of the extremely deep-down customizing that ACE allows for and provides, and the software is about as powerful as they come.
