New and exciting startup error
I've been using ACADE 2015 for months without issue. Closed down last night properly, then started Electrical this morning, only to receive attached error messages before the program summarily crashed out. I've done the usual reboot, along with a program repair using our source files but still getting the same error. Anyone else seen this before, or even better, anyone got a workaround?
Yong.Jing
Autodesk Support
Autodesk Support
Have you tried as below steps:
Close ACADE
Open windows search window
Type <PROJECT NAME.MDB> in the file name box
If project is on a network, select the drive where project is stored otherwise select your C: drive
start search
select the <PROJECT NAME.MDB> file when it comes up
Press the DELETE key
Restart ACADE and open the project
Hopefully everything is now ok
If not, do a full rebuild of the database
You could see more detail at this link
Yong Jing
Product Support Senior Specialist
Technical Support, CSS, GPS
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
如果我的回帖解决了您的问题,请点击 "接受为解决方案" 按钮. 这可以帮助其他人更快的找到解决方案!
Thanks. I found a solution: Uninstall and reinstall Microsoft Access database engine 2010.
