AutoCAD Electrical Forum
Multiple Source / Destination Arrows
3 REPLIES 3
janssen_l
1228 Views, 3 Replies
Hello Community,
I'm having difficulties to understand the usage of multiple Source / Destination arrows.
My use case:
I have a start point from which a wire (source arrow "TS2+") jumps onto another drawing (destination arrow "TS2+"), then the wire goes through two terminals and jumps to another spot on the same drawing (source / destination arrows "TS2+-01"), where the wire goes again through 2 terminals, then it jumps again on another drawing (source / destination arrows "TS2+-02"), where it does the same (through 2 terminals, jump "TS2+-03", through 2 terminals) and then end at the last terminal.
The wire is marked as "JUMPER / no wire numbering"
3 REPLIES 3
testsubject
in reply to: janssen_l
I am not sure what is going on by what you posted.
I do multiple Source/Destination codes on the same page and use the format that you described.
What seems to be your issue?
Bob Hanrahan
Ace User since 1998
If this answered your question, please click on "Accept Solution"
dougmcalexander
I'm not sure I understand your question, but I will attempt an answer.
One source can feed multiple destinations.  However, you cannot connect more than one source arrow to a destination.
For page-to-page jumps, the simplest method is to make the source and destination code for each pair unique.  Leave the page with a source and continue on the next page with a destination that has the same code as the source on the previous page.  For example:
Page 1 source...SIG000        Page 2 destination...SIG000
Page 2 source...SIG001         Page 3 destination...SIG001
Page 3 source...SIG002         Page 4 destination...SIG002
ETC.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in AutoCAD Electrical training and implementation support
Phone and Web-based Support Plans Available
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please Accept as Solution if I helped you. Likes are also much appreciated.
janssen_l
… beginners fault -> database refresh needed...
Technology Administrators
AutoCAD Beta
