Multi-level terminal block from secondary DB.
I use multi-level terminal blocks weidmueller.
When working with the primary DB default_cat - selection from the catalog and assignment of properties occurs normally.
When working with the secondary DB - problems. After selecting the terminal block type, the Manufacturer and Catalog number are assigned, but the terminal block levels are not assigned.
I create the secondary DB manually.
The tables have the same columns.
_TERMPROPS - empty
_TERMPROPS_WEIDMULLER - has terminal block data
TRMS - has terminal block data.
Tell me, what could be the problem? When using a secondary DB with relays or buttons, there are no problems.
