Missing Workspace Option
gallenFPYAF
gallenFPYAF
I have AutoCAD Electrical 2026. After a default reset, I noticed I didn't have any of my electrical tabs in my ribbon. Go to add them back and they are not an option. I am no longer able to open projects. AEproject is not a known command anymore. Go to my workspace selector and the electrical option is gone as well. What do I need to do to get it back?
arshdeepsingh404
Do you have the electrical profile available if you run the CUILOAD Command?
If not, can you try browse and load the acade.cuix file which is usually located under: C:\Users\Username\AppData\Roaming\Autodesk\AutoCAD Electrical 20##\R##.#\enu\Support
Arshdeep Singh
Electrical Designer & Programmer
C.Tech | CAPM | CMSE | Autodesk Expert Elite
LinkedIn | Autodesk App Store | GitHub
Did you find this post helpful? Please feel free to Like this post.
Did your question get successfully answered? Please click the Accept Solution button to help other users who may have the same question.
gallenFPYAF
It wasn't available. I loaded it. Now this is what it gives me.
arshdeepsingh404
Hi @gallenFPYAF
Sounds like something wrong with the cuix file or missing paths in profile.
Checkout the following articles:
Menus and ribbons show question marks in AutoCAD Products
Question marks icons display on customized toolbar or ribbon in AutoCAD product
Worst case, you can try simply reinstalling acade to fix anything that broken.
Arshdeep Singh
