AutoCAD Electrical Forum
Missing attribute in symbol builder image
6 REPLIES 6
love.lustig
257 Views, 6 Replies
I'm creating a basic user defined terminal with attributes both above and below. These attributes have a tag name, a prompt and a value of XX. I want the value XX to be visible on the image that is created when I save but it is not.
On other symbols I have created it works fine, I can't figure out why this one is not working. Any ideas?
I have attached both Image .png file and the .dwg file.
6 REPLIES 6
alds02
in reply to: love.lustig
Looks fine when I drag it into a file:
Delete all instances from your drawing and use the purge command. Then try again. Does that work?
love.lustig
in reply to: alds02
Yes, the symbol works as intended. But the image dosen't show the attribute values for some reason.
rhesusminus
The texts are there, they're just located outside of the square image because AutoCAD Electrical doesn't pay attention to the text justification of the attributes when generating the preview 😞
Adding some graphics will show them....
Trond Hasse Lie
AutoCAD Electrical and EPLAN expert
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
love.lustig
in reply to: rhesusminus
Thats intresting. I wonder why the attributes is vissible on some images but not others. I can't seem to find any differences.
rhesusminus
I guess it has to do with the location/justification of the attributes in the other symbols. If you can post an example symbol where it works, maybe we can figure this out.
Trond Hasse Lie
Ctrl Alt El
galashkina
I changed the properties of the TAG1 and LOC attributes to visible.
The attachment contains the modified file.
Technology Administrators
AutoCAD Beta
