make Cable Conductor List with Wire Numbers?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'd like to be able to make a quick report or list of the conductors in a cable.
-show the conductor # list
-show the associated wire number for each conductor
-ideally work in schematic or panel dwgs
We use standard cable parent and child markers
If I run an XREF on a cable, it "almost" works, but the list omits the parent conductor
We don't always assign LOC codes at either end, so the "From/To" report might not help
Our current workflow:
-in schematic, draw cable using standard cable and child markers
-in panel/layout drawing, insert the cable (we have circles representing the cross section of the cable, but could be anything)
-from Panel ribbon item, choose "Wire Annotation"
-in the popup dialog, select "Wire Number Only"
-we get a text table, but again, I believe it omits the parent conductor
{I think we edited "by hand" to show the parent}
-example result here below
In this example, our wire number format is SSSRN, so this cable appeared schematically on sheets 520,560,561,562
{We should have had an XREF to the cable conductor child, I missed that in this example}
What's the motivation:
-for cables that span several sheets, its a convenient way to visualize what's been used so far
-convenient for wire man
~we probably don't want to use it on "simple" cables that only span a single sheet - ie we'd like to "pick" on the ones we want to report
