Item Balloon Missing Ellipse
I am using the exact same settings as my co-worker. I double checked and everything is exactly the same in the "Panel Balloon Setup" Dialog box.
When he inserts balloons they always have the ellipse drawn around them. (Settings:https://i.imgur.com/7E3z75c.png) When I insert balloons only a number is inserted, with no ellipse. I have to change the text size to 0.125" in order to force autocad to draw the ellipse, and then go in manually and change the text size.
I even opened one of his drawings that had the ellipses on the item balloon, and tried inserting a new item balloon. It shows up without the ellipse in his drawings, and I have the same settings as his "Panel Balloon Setup" dialog box, so it must be a setting in a different place in Autocad.
See attached for examples of both. The good item balloons my co-worker made and  the bad ones from my computer.
rhesusminus
which are the bad balloons?
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
Looks like the file didn't attach for some reason. See attached for the bad balloons
rhesusminus
I was hoping to see a drawing with the broken balloons you created. This drawing had NO balloons in it, and inserting some on my computer went fine.
Trond Hasse Lie
Ctrl Alt El
