How is it that there hasn't been an implementation yet to have multiple rows of tabs visible at the same time?
I may have misinterpreted your post, but, since release 2014, there are tabs - one for every drawing you open. You can click them to move from one open drawing to another.
Having multiple drawings from the same project open at once presented some issues for the Electrical data manager when AutoCAD started allowing this, but the programmers have worked very hard over the years to equip the data manager to maintain a healthy database, even as drawings are open and in flux. I personally try to keep the number of open drawings to a minimum though.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor
Specializing in AutoCAD Electrical Implementation Support
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Jim, I wonder if he is referring to the ribbon menu tabs? They do compress and become fly-outs if the screen isn’t wide enough to support the resolution.
The way I teach the software is to keep a minimum number of drawings open. I never saw a database crash until Multiple Document Interface was introduced and Electrical was forced to accommodate it.
If I have enough drawings open that it would require a second row, I am seriously tempting fate, when it comes to database integrity, not to forget the drag it places on computer resources.
Doug McAlexander
I guess I am more conservative. I want to see current features made more “bullet-proof” before introducing new features. Anytime sonething new is added, it has the potential to break something that has been working fine. This is called regression in the programming world.
For example, there is a serious problem with the past three releases for those who sequentially number their wires, if they also use the Terminal Jumper utility to designate jumpers between schematic terminal symbols, and those same circuits use source and destination arrows to continue across multiple drawings, such as a power bus. Inserting wire numbers drawing wide will result in different wire numbers than when inserting wire numbers project wide. This is a serious integrity issue.
Doug McAlexander
I typically have between 5-10 drawings open at once but I definitely close all but one if I am doing a signal update. If you don't the text justification go all wonky.
