Is there an easier way to find components?
I have a major problem when I am creating schematic drawings.  I have become somewhat familiar with the components that are available in the software, however, there are some basic ones that I find hard to believe are not included.  For example, I would like to insert a ground symbol.  Under the Schematic tab I click the "Icon Menu" button, and go searching through all the categories and cannot find one.  So, easy enough, I draw one myself, no biggie, but I find myself fighting the battle between drawing symbols myself and searching for them too frequently. What am I missing?! Certainly there is supposed to be a Ground symbol in this library.
Thank you!
Have you tried "searching schematic components" by using Catalog List, Equipment List, Panel List ? There are schematic components libraries where you will find component you are searching for. Also In "Insert Component " Dialog box; if you Browse By name of .dwg component it will display Library menu. As you become more familier with Schematic Components library; searching component will also become easier and faster.
The gound and earth symbols are in the miscellaneous folder of most librarys.
Icemanau
Among the first things I do with each new install, I re-arrange the component menu so that all the symbols I use most frequently are only one or two levels down and easy to find.
This would include creating a new menu catagory for earth connections that are lumped under miscelleaneous and adding the child earth symbols (with screw number) to the list. I also add a terminal number to the existing parent for use on multi terminal earth bars.
Regards Brad
Brad Coleman, Electrical Draftsman
PatMurnen_Adsk
You can search in the product Help for a symbol. In the search results look for topics that include Symbol Preview in the title. It will tell you what library set it is included with , i.e. IEEE, IEC-60617, etc. The topics are organized like the default Icon Menu so you can use the title to locate it in the icon menu.
Hope this helps,
Pat Murnen
Pat Murnen
Principal Content Developer
Product Development – AutoCAD Product Line Group
Autodesk, Inc.
