AutoCAD Electrical Forum
Is it possible to Check in the AutoCAD Electrical Drawing Project into Vault with the Vault Add-in?
1 REPLY 1
JKFarmerMold
319 Views, 1 Reply
I am not a major user of ACAD Electrical (ACADE) but have had to open up drawings a few times here and there and I understand that ACADE generates a 'project' that is used to manage multiple drawing files.  So my question is that when I used the Vault add-in, during check-in/out is it possible to include this 'project' file?  I do not recall seeing a include files button that I use often when using Inventor for files, and have used the Vault client to add the 'project' file after the fact so that it is at least in the system.
1 REPLY 1
rhesusminus
in reply to: JKFarmerMold
Inside AutoCAD Electrical, you'll find the project manager. When you right-click the project inside AcadE, you'll get options to check out/in partial/all drawing sheets in the project.
You really should do it this way, as there are other things happening in the background. There's some other metadata that's also included in the check-in.
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
