- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
For about a week now, I have been experiencing a problem while inserting TB's into a drawing. The problem occurs when I attempt to Insert/Edit Terminal Symbol or add a terminal block by copying an existing terminal block. Just for clarity, I should make it clear that the terminal blocks that I am inserting are not the default AutoCAD terminal blocks, but a terminal block 'BLOCK' that we have created for our drawings.
Regardless of whether I insert a new terminal block,, or copy from an existing, the Insert/Edit Terminal Symbol box appears as normal (picture attached), and allows me to select the correct Installation, Location, Tag Strip, and Number. After selecting all the appropriate information, I click OK to insert the TB on the drawing. When I select the insertion point on the drawings, the terminal block appears, but without any of the information that I selected in the Insert/Edit Terminal Symbol window (picture attached). Upon inserting the 'blank' terminal block, the following text appears on the command screen, "Error: no function definition: VLAX-ENAME->VLA-OBJECT" (picture attached).
I have been using these terminal block 'BLOCK's for years, and this problem has only started to occur in the last week or so. It now happens every time I insert/copy a terminal block. I have attempted to reinstall AutoCAD on my machine, but the problem has continued to occur.
