Inserting Project Description information on sheets
Hi all,
I'm looking to insert some project description information on sheets (not in the titleblock), is there an easy way to go about this?
Thanks much
rhesusminus
Can you be more specific? Where do you want to put the project descriptions?
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Autodesk Expert Elite Alumni
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
I'm looking to put, for example, the Title of the project on the cover sheet, and on project information on other sheets.  I might reference revision changes as well.  I'm contemplating simply using reports, but that seems like a lot of steps for just a small bit of data.
rhesusminus
If you use the WD_TB option for linking data to the title block, you can have multiple blocks with the WD_TB attribute in it.
Here I've created one more block and linked  LINE1 and LINE2 to the attributes.
When I run a title block update, it updates all blocks with the WD_TB attribute in it.
Trond Hasse Lie
Ctrl Alt El
