AutoCAD Electrical Forum
Insert Block Dialog Box display whenever inserting Source/Destination Arrows, retag/update, edit wire number etc
4 REPLIES 4
pvpatel
558 Views, 4 Replies
pvpatel
Any idea why the insert block dialog box displays whenever trying to insert the source/destination arrows, use the retag/update or edit wire number command? It seems like the command doesn't know what default block to use in the background so it displays the dialog box for user to pick the correct block. The support paths are correct and the project settings are also pointing to the correct symbol library paths. Using AutoCAD Electrical 2019.
Thanks!
Thanks!
4 REPLIES 4
JeffatPrimex
in reply to: pvpatel
JeffatPrimex
Does it work if you type in AESOURCE ?
Best regards,
Jeff
Best regards,
Jeff
pvpatel
in reply to: JeffatPrimex
pvpatel
Same results.
Thanks!
Pravin
Same results.
Thanks!
Pravin
ramesh.kambang
ramesh.kambang
Does this on both source and destination arrows?
Try few options:
option 1: try on one of the iecdemo or wddemo project drawings.
option 2: purge all blocks and try it
Option 3: check symbols HA1Sx and HA1Dx or VA1Sx and VA1Dx where  x is number 1, 2, 3 ...... in the library. Probably they are overwritten recently.
option 4: reset acade to default settings
Ramesh Kambang
Aerospace System/Design Engineer and eVTOL/EWIS Expert
EASA 21J, UK 21J, MAA DAOS, Certification Specification CS23-29, CS-ANCS, CS-STAN and EVTOL
Please select "Accept Solution" if this post answers your question.
Try few options:
Ramesh Kambang
pvpatel
in reply to: ramesh.kambang
pvpatel
Had to go with the Option 4 that solved the issue!
Thanks!
Pravin
Thanks!
Pravin
