AutoCAD Electrical 2020
Issue started Monday 2/10/2020.
First thing I noticed was the files Date modified showed 4/14/2010 5:09 AM (does this for every export), once I try to open the file I get the message: 'filename.XLS' cannot be accessed. The file may be corrupted, located on a server that is not responding, or read-only. After failing to open the file, the Date modified changes to the correct date and I may or may not be able to open the file.
To see if it was a corrupted project I tested a few different projects that worked before but it does the same thing.
Also since Monday, another odd thing is sometimes when I launch ACADE, it fails to launch or takes longer than I've waited (around 5 minutes). Task Manager - End Task then relaunch has worked every time so far.
