Import Data from spreadsheet not importing data
- Mute
- Permalink
- Report
Hi All,
I posted this problem back in October of 2015. I'm semi-reposting it again because the issue still persists. In a nutshell, the Import Data feature is not importing/updating to the drawings all the data I edit in the exported spreadsheet. When I say "all the data", I mean all relevant data in the following tabs: COMP, TERM, WIRENO, PNLCOMP, & PNLTERM (more on that below). The results are a mixed bag leading to one of the following outcomes:
- The entire sheet updates according to the changes made to the spreadsheet, or
- Some sheets have certain schematic child symbols updated, but their schematic parent symbol remains unchanged, or
- Schematic parent symbols are updated, some of their child symbols change, but their peer on the wiring diagram/panel layout remains unchanged, or
- The entire sheet is left unchanged.
NOTE: The same mixed results outlined above apply to wire numbers and terminals throughout the project.
The unpredictable results make it difficult to troubleshoot the problem. Before I import the data 'From Spreadsheet', all parent symbols, child symbols, and their peers share their respective INST, LOC, & TAG attributes and fully link to one another in the project. They can be surfed from one sheet to another, so the relationships are verified prior to running the update.
I'll use the same example I used in my previous post to outline the steps I take:
J1012 is an old panel designation and J1008 is a newly added panel designation that is an exact copy of panel J1012, except for the obvious name changes. Steps:
- I copy project J1012 and rename the copy J1008.
- I click 'Import/Export Data > To spreadsheet', select "General", select "Project", and the spreadsheet opens.
- I proceed to change ALL instances of J1012 in the spreadsheet to J1008 in the COMP, TERM, WIRENO, PNLCOMP, & PNLTERM tabs (INST, LOC, TAGx, etc, etc.).
- I change ALL wire numbers and terminals to match the new panel data.
- I save and close the spreadsheet.
- I click 'Import/Export Data > from spreadsheet, select Project, and let it go about its business.
That's it. I can't think of why AutoCAD is selectively changing certain fields and not others, when all fields in question were changed in the spreadsheet. I'm not messing with the format of the individual cells or the column headers in any way. All of the canned "demos" of this feature show an automated, flawless updating process that really sells the product. The nature of the work I'm doing required 100% customization of all symbols, blocks, etc. so a standard demonstration of the tool doesn't help me much.
Any helpful info will get enthusiastic kudos. 🙂
Tim T.
P&C Designer
Substation Relay
Ampirical Solutions, LLC
