IEEE 315/315A IEC-60617 NFPA missing in the full version of Autocad electrical 2021
rso2
rso2
When I click on the 'ICON MENU' , it just shows the symbols for JIC.  I'm trying to insert electronic/electrical components such as resistors, capacitors, etc.  Understand these would be located in the following libraries however I can neither locate them under Icon menu nor the project settings.  Please advise on how to install these libraries.  Thank you.
  • IEEE 315/315A
  • IEC-60617
  • NFPA
ramesh.kambang
Install/select libraries per the marked in RED below.
Ramesh Kambang
Aerospace System/Design Engineer and eVTOL/EWIS Expert
EASA 21J, UK 21J, MAA DAOS, Certification Specification CS23-29, CS-ANCS, CS-STAN and EVTOL
Please select "Accept Solution" if this post answers your question.
rso2
Hi Ramesh,
Thanks for your reply.  I went to my autodesk  app however I do not see the option 'Install> configure installation' as shown at the top of your picture.  Attached is my snapshot.  Please advise. Thanks again!
ramesh.kambang
You need to run the AutoCAD electrical installation file. Installation automatically detects the previously installed files but allows to select/install previously not installed libraries. See the link below for full installation, hope this helps.
https://www.youtube.com/watch?v=pQqS0YWa5tg
Ramesh Kambang
