Can anyone let me know if Autodesk or another site offers a add-in package for IEC Standards? I know that it comes preloaded with the JIC. However we use IEC. Any help on this would be greatly appreciated.
From the Control Panel/Programs/Uninstall a Program, select Autocad Electrical 20XX and when you get to the Installation Dialog Box, select Add or Remove Features and select all the symbol styles that you want. It is also from here that you can add manufacturers to the database.
ACE by default installs only the JIC Library (we should be given the option to pick which library)
Actually you do get the option. If you select IEC as your default design style you will get the IEC libraries instead of the JIC.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor
Specializing in AutoCAD Electrical Implementation Support
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Doug McAlexander
Hi Doug,
I've also encounter same problem with IEC symbols, as you were saying it has an option wherein the default drawing can be set to IEC, can you please tell how can this be done. Please forgive me, I'm still new in autocad electrical. Thanks in advance.
Hi Doug,
I have been able to load the IEC Library but some of the slides are loading the IEC Symbols and some or still loading the JIC symbol!
Example: The title says IEC: Push Bottons, and the preview is showing the correct IEC symbol for push button, However when you click on the push button icon it shows up as a JIC symbol in model space. It is not doing this for all the slides, just certain ones.
Can anyone shead light on this subject?
The first place I would check is in the Project settings and verify which libraries are selected in the "Libraries and Icon Menu Paths" section. This area determines which symbols are inserted from the menus. These setting are Project specific.
Doug McAlexander
Doug McAlexander
Good Idea Doug. I forgot about that.
In my Schematic Libraries I removed the “JIC” ones and added the “IEC-60617” and moved it to the top. My Schematic Icon Menu File reads
“ACE_IEC-60617_MENU.DAT”
My Panel Menu is still set to the default. Would that need to change as well?
Doug McAlexander
Doug McAlexander
The panel menu and library is the same for all. The footprints are physical representations and therefore look the same in any standard. However, the footprints are in English units, not Metric. You should go to the Panel configuration menu and set a scale factor of 25.4 if inserting the footprints into a Metric drawing environment.
Doug McAlexander
Doug McAlexander
First of all, BACKUP all your dwgs in the project in case of problems.
Now go to the Swap/Updat Block function.
In the Update block section, there is a way to swap all blocks to the equivelant block in a different library. Use this to update all your existing blocks at once.
Then do a full rebuild of the project before you double check that everything is correct.
Regards Brad
Brad Coleman, Electrical Draftsman
Regards Brad
Hi Bob,
Thanks for the tips, it helps to solve my problem.
Cheers,
Eric
Hi Bob,
Cheers,
Eric
The Panel menu stays the same because it is a physical representation of the part which does not change.
Glad I could help. Please mark this as resolved.
Doug McAlexander
Doug McAlexander
