AutoCAD Electrical Forum
How to turn off lighting option in Drawing UNIT dialog box.
5 REPLIES 5
1153 Views, 5 Replies
I am working on AutoCAD electrical 2019 Automation project, recently While running code on (Inserting Block in AutoCAD)  Drawing. below dialog box appears. need to close it manually.
While solving issue I found in Drawing unit setting under lighting options , "American" is select please referee below image.
This above pop up appears only if the lighting option is selected. else if it blank then dialog box not appears.
if I click on this option then, there is only two choice, "American" and "International".
There is no blank choice.
Can Any one help me two solve this issue,or how to set lighting option blank.
Labels (3)
5 REPLIES 5
JeffatPrimex
lightingunits = 0
Best regards,
Jeff
in reply to: JeffatPrimex
No.
lightingunits cant be set to 0 since acad 2017...
rhesusminus
Thank you for sharing not the solution yourself.
Trond Hasse Lie
AutoCAD Electrical and EPLAN expert
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
in reply to: rhesusminus
Hello Grouchy
No solution apart from a macro.
This is a quick sample:
(defun insert_my_noscaleblock ( / oldinsunits oldINSUNITSDEFSOURCE oldINSUNITSDEFTARGET myblo )
(setq oldinsunits (getvar "insunits")
oldINSUNITSDEFSOURCE (getvar "INSUNITSDEFSOURCE")
oldINSUNITSDEFTARGET (getvar "INSUNITSDEFTARGET")
(if oldinsunits (setvar "insunits" 0))
(if oldINSUNITSDEFSOURCE (setvar "INSUNITSDEFSOURCE" 4))
(if oldINSUNITSDEFTARGET (setvar "INSUNITSDEFTARGET" 4))
(setq myblo (getfiled "" "" "dwg" 2))
(command "_insert" myblo)
(if oldinsunits (setvar "insunits" oldinsunits))
(if oldINSUNITSDEFSOURCE (setvar "INSUNITSDEFSOURCE" oldINSUNITSDEFSOURCE))
(if oldINSUNITSDEFTARGET (setvar "INSUNITSDEFTARGET" oldINSUNITSDEFTARGET))
Et voila
rhesusminus
Much better answer, so I accepted it. And I hope you get my point...
Trond Hasse Lie
Ctrl Alt El
Technology Administrators
AutoCAD Beta
