AutoCAD Electrical Forum
How to quickly add more attributes to all symbols, instead of editing them one by one?
13 REPLIES 13
Message 1 of 14
822 Views, 13 Replies
I already created 50+ user-defined symbols. Now I realized the company may want to add in a couple more attributes to all of the symbols. Is there any way to add in the extra attributes quickly, instead of opening every single dwg file to edit one by one? It would be awful if I have to edit each of every single dwg file.
sincerely,
Paul Chen
13 REPLIES 13
Message 2 of 14
rhesusminus
You can do this manually, by opening each symbol.
Or, you can code something that do this for you.
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
Message 3 of 14
in reply to: rhesusminus
oh no... So, you are saying I have to make a AutoLISP or Python to automate the process? My boss told me they cannot be sure what attribute names for all the symbols, and they have to update more attributes over the year. It'll be disastrously tedious to update one by one manually.
sincerely,
Paul
Message 4 of 14
rhesusminus
And the location of those attributes must also be considered in your code, and yes, AutoLISP. Should they be visible?
Can you tell us the reason why you want to do this? There might be other solutions.
Trond Hasse Lie
Ctrl Alt El
Message 5 of 14
No, they don't need to be visible. We basically want an extra column of data in the Excel Spreadsheet. Say, if I added a location number to all the symbols, then the Excel spreadsheet would show that extra column of data.
sincerely,
Paul
Message 6 of 14
rhesusminus
How will you add data to these settings?
Via the edit component dialog?
Is it just for the parent symbols?
The more detailed you answer, the less questions from me 🙂
Trond Hasse Lie
Ctrl Alt El
Message 7 of 14
Hi Trond,
Right now, the method I know is go to Schematic > Symbol Builder. Open each individual symbol dwg file to manually add in the attributes. (Please see screenshots and explanation)
note: all the symbol dwg files are created as parent symbols.
sincerely,
Paul
Message 8 of 14
I really need someone to help me out on this. I've now made 80+ symbols. But my boss suddenly expects me to add in new attributes into ALL OF THE SYMBOLS. I don't need the new attribute names to be visible. They just need to be associated with each of the symbols.
Examples:
Name
Alias
ID
KV
BIL
Rating
In-service date
Removal date
How can I add attributes quicker, instead of opening and editing each and every DWG file?
sincerely,
Paul
Message 9 of 14
rhesusminus
You WILL need to code something to do this. There is no easy way.
Once the code is made, you can execute it on the entire symbol library using the "modify symbol library" tool.
When that is done, you can run the "update/swap symbol" function to replace all symbols in your project with the new version.
This is a LOT of work, so I hope that you're boss don't expect anyone to do this for free for you.
Trond Hasse Lie
Ctrl Alt El
Message 10 of 14
Trond,
Thanks for your response. We are still probing around how to process the conversion from AutoCAD to AutoCAD Electrical. But yeah, I'd say 80+ is still manageable for me to do manually. But later on, someone else would take it over and expand the library. So, we need to figure out a way to automate the process.
Do you know where we may find people who provide coding services? I suppose this is AutoLISP coding?
sincerely,
Paul
Message 11 of 14
rhesusminus
For this I guess you can just ask in the autolisp forums. But for many other things you need later you also need them to know AutoCAD Electrical, and this would be a more rare combination.
Trond Hasse Lie
Ctrl Alt El
Message 12 of 14
metal_pro2
If I were you I wouldn't add those attributes - they are not AutoCAD Electric standard attribute names so you will not have any benefits of AutoCAD Electric like parent - child or single line relationships, reporting tools etc.
You should use the standard AutoCAD Electric attributes.
Use the AutoCAD Help and search for "About Schematic Attributes" then read, read read
For example use:
"DESC3" for Name
Rating6 -Alias
Rating7 ID
Rating8 KV
Rating9 BIL
Rating10 - Rating
Rating11 - In-service date
Rating12 - Removal date
If you need to add the same attributes to 80 symbols you could create a AcadE project of the 80 symbols (say No to apply project default values to drawing settings) then use "Project-wide Utilities" to run a command script on the 80 symbols.
The command script would just insert a exploded block of the additional attributes into each drawing.
Do some reading on scripts in help search for  "To Create a Project-Wide Script File"
Message 13 of 14
alds02
in reply to: metal_pro2
I second @metal_pro2 's advice. Repurpose an existing attribute if possible.
Message 14 of 14
Thanks for your advice @metal_pro2  @alds02 . I have imparted the concern to my boss. But he still wants me to test it out first. I'll update y'all.
sincerely,
Paul
