AutoCAD Electrical Forum
How to correctly use the separator '|' in the cross-reference tab under settings in AutoCAD Electrical?
4 REPLIES 4
samirguptaG6MSM
322 Views, 4 Replies
When I use the separator '|' in the cross-reference tab under settings. The separator '|' changes the XREF attribute to multi-line text. This breaks the hyperlink between the parent to child if contacts are more than 1. The attached pdf print shows the example. Case#2 shows the parent with multi-line text (with reference '|').
Although when using the comma "," as a separator the hyperlink works as shown in case#1 in the attached pdf. Is there a way to use the separator '|' and have the hyperlink work?
@samirguptaG6MSM
The topic title has been edited to improve findability by @alina.balkanskaia. Original: Text Cross-Reference Format Setup and Hyperlink Issue
Labels (3)
4 REPLIES 4
Hello, @samirguptaG6MSM 😀 Nice to see you in Autodesk Community! I hope you will get answers very soon! Please let us know what version (year) of AutoCAD Electrical you use.
Alina Balkanskaia
Since your original thread title was changed, I spent a while looking at things that didn't matter. Your original title was fine, I don't know why it was edited.
Despite the misleading/inaccurate new title, you appear to already be using the | separator correctly and as intended. It's just, that title has nothing to do with your actual problem, which is, using the | separator breaks the hyperlink in the PDF.
Your only other option to try is the command 'Change Cross Reference to Multi Line Text', found at Schematic>Edit Components>Component Cross Reference [pull-down]>Change Cross Reference to Multi Line Text.' This will actually destroy the XREF attributes and replace them with MTEXT. ACADE will still update the references when they change, Surfer still works, etc. About the only thing it does is, if you click on the references it opens up the MTEXT editor window, whereas before, clicking on the references would just select the whole symbol.
Now, I have no idea if this will preserve your hyperlinks in the PDF. I don't make use of those. But, I can say that this is the only option you have for creating multiline cross references without using the | separator.
Be sure to post back and let us know how that goes.
Jim Seefeldt
Electrical Engineering Technician
AutoCAD Electrical 2020
Yes, the surfer works with no issues. But the hyperlinks are broken dues to MTEXT I think.
Thank you for your response this was helpful
