Hi @Ahmed_mohamedHC52L
Do you have Home tab available under the regular AutoCAD CUI file?
You can check by switching to acad.cuix
If yes, You can try using the Transfer Tab to copy the Home Tab out of acad.cuix to acade.cuix
Default location for cuix file:
C:\Users\UserName\AppData\Roaming\Autodesk\AutoCAD Electrical 2025\R25.0\enu\Support
(AppData is usually a hidden folder so you might want to either type the destination folder address or enable show hidden folders)
And then try dragging and dropping the Home tab to the current ribbon.
If still no luck, You might have to restore your CUIX to default AutoCAD Electrical CUIX and do the customizations all over again. I know its not great but I had to do that when I was first learning how to modify cuix and broke it.
That's why I always take backups now before modifying so I can restore to the last working version if anything goes wrong.
This article below has a section about Restore the backup file for the CUIX
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Error-The-Ribbon-d...
Arshdeep Singh, C.Tech, CMSE®
Electrical Designer & Programmer
Please mark as [Accept Solution] if this resolved your issue. It might help someone else with the same question. Likes are welcome!
