How Can I make Components Cross Reference Standalone Sheet in Autocad Electrical ?
Message 1 of 8
Dear All
I am using AUTOCAD Electrical 2015 , I want to make A Components Sheet with Contacts Cross Reference Like The One Attached
Best Regards
Replies (7)
Message 2 of 8
Icemanau
I'm not sure where this hides on the ribbon but there is a tool to insert stand alone cross references.
Make sure your Menu Bar is showing. Click the drop down chevron at the end of the Quick Access menu to turn it on.
Click on Components and hover over cross references.
Stand Alone Cross References is the second entry from the bottom just under a separator on the flyout menu.
This may allow you to set up a sheet like your example.
Regards Brad
Brad Coleman, Electrical Draftsman
Message 3 of 8
huggy_d1
After looking at the provided eplan output, I see a very custom report, and many hours manually dropping in the items contained in those xref pages by location.  What drawing format are you using to create the drawing and xref pages?  Certainly not JIC/JIC125 or NFPA.
Message 4 of 8
rhesusminus
While I don't think these are made in EPLAN (Rather See Electrical, owned by Schneider), you just can not create "graphical reports" in standard AutoCAD Electrical. It CAN be done using custom programming.
You can do it manually, by using stand-alone cross-references, as Brad and Don said.
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Autodesk Expert Elite Alumni
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
Message 5 of 8
Dear Sir
How can I link Text to Component Cross Reference ?
Best Regards
Message 6 of 8
Dear Sir
This Report is done Manually with AutoCad, That's Why I decided to change to Autocad Electrical but Now, As you said it will be also done manually !!!!,
At least I need to know How to link Text in square to component Cross reference ?
Message 7 of 8
This is not working As u have to use source and Destination Together, I need to link text in squares to components cross reference
This Sheet is normally inside any schematic , I don't imagine that Autodesk has no way to do it automatically
Message 8 of 8
rhesusminus
You should be able to do this manually.
Create a child symbol. No connection points. Make sure it has an attribute named CONTACT, and this attribute has a default value of NULL.
insert this symbol, and connect it to the parent component. It will now have a "live" cross-reference to the parent symbol.
Here's a link to the symbol I've used in the screenshot above:
https://www.dropbox.com/s/qkkrhzsbax2gjwu/VMO2_WD.dwg?dl=0
Trond Hasse Lie
Ctrl Alt El
