Hello I had an old file opened and imported a new file, designed the new file and saved it. The new file is displayed, but when I go to plot, the old file is being plotted and previewed. Can some help with this? Thanks
The topic title has been edited to improve findability by @alina.balkanskaia. Original: Plotting the old file
Solved by alina.balkanskaia. Go to Solution.
What did you import into the file before saving it as a new file? Which commands did you use?
Did you delete any of the old information?
How is the drawing plotted, is it from model space or from paper space?
old file was a dwg, I did not delete the old, trying to plot from the model space but it is converting to the paper space
@dedrick.torry Hello, nice to see you in Autodesk Community! 😀 Would you be so kind as to show the file? It could help Experts to get the answer.
Here is the file also how can I print the file where the document is more readable its blurry
