AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Fuse and fuse-holder
29 REPLIES 29
Message 1 of 30
DWhiteley
10243 Views, 29 Replies
I wish to add a fuseholder and a fuse to a schematic.
The fuse holder is easy, but how would i add a fuse of a particular rating to this (a bit like a sub-assembly or parent/child I suppose)?
Both parts would have to come up in the BOM.
Dave W
29 REPLIES 29
Message 21 of 30
james_moore
in reply to: testsubject
Yep, for any RATINGs to apply, they must be entered in the TEXTVALUE field, and they only apply when you are selecting the "master" part. So, this is where using a combination of ASSYCODE and multiple catalog comes in. For instance, you set a combination of fuse holder & fuse for a 2A fuse. If you need more than one of these to allow you to have different combinations of other parts you'll include using multiple catalog, you'll need separate records with unique ASSYCODEs for each unique combination of parts.
Message 22 of 30
james_moore
I would want every fuse holder to have the same item#, but what we have is every fuse holder and fuse size combo ends up as an assembly "item."  So if I have 5 of the exact same combination of parts, that's five "items", even though the fuse holder may appear as multiple items... because it's an assembly, not a "part."
Message 23 of 30
testsubject
in reply to: james_moore
That is what I do not like about using assembly codes.
Bob Hanrahan
Ace User since 1998
If this answered your question, please click on "Accept Solution"
Message 24 of 30
rhesusminus
And this is exactly why I use a different software. The AcadE way just doesn't make sense.
This topic appears every now and then on these forums (video):
https://forums.autodesk.com/t5/autocad-electrical-forum/how-to-inset-2p-or-3p-fuse-switch-footprint/...
Trond Hasse Lie
AutoCAD Electrical and EPLAN expert
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
Message 25 of 30
james_moore
in reply to: rhesusminus
Whether or not it makes sense depends on your engineering environment and standards.  It works for us. 😉
I don't always like the way things are either, but I appreciate the open-ended nature of the overall system.  IMHO, one key to success with ACE is learning to follow the system before forcing the system to work the way you want it to.
I've seen it commented elsewhere that "AutoCAD Electrical is designed for drafters, not engineers."  I disagree...  It is a garbage-in, garbage-out tool, designed for on-the-fly database-based engineering.  It's complexity is it's strength and it's weakness at the same time.
Message 26 of 30
rhesusminus
in reply to: DWhiteley
@james_moore Stockholm syndrome 😉
Trond Hasse Lie
Ctrl Alt El
Message 27 of 30
james_moore
lol, I'm just not into starting over after 30 years experience.
I believe every product has limitations once the "herded cats" get their hands on it.  It's always "ooo, ahh! I could never do that before!" followed by "why can't I do this like I want to?"
One big one for me (maybe EPLAN is no longer like this, I'm sure you'll correct me if so...) is dependence on the manufacturer of the software for my data library.  I design custom footprint blocks and schematic symbols around my company's drafting & design standards, and my part catalog data is often appended or modified with new parts.  My ability to add these things without whining to a software developer somewhere and waiting on them is very important to me.  We don't use Siemens, we use Allen-Bradley.  We don't use much Phoenix.  We use SmartScan and Fortress safety devices. We use some IDEC relays.  Aside from A-B, we don't find these parts in the ACE library, but I normally can add a part in minutes.  Even the A-B parts and Hoffman parts that are well represented, we have modified so we get what we want on our designs efficiently without a lot of post-insert adjustment.
If by stockholm syndrome you mean I have too much invested in AutoCAD to start over either talking engineers into modifying department's practices and standards, or tweaking a new package to suit said engineers, managers, assemblers & wiremen, purchasing department people, & device/wire tagging practices, you are correct sir. 😉
Message 28 of 30
Add the attributes MFG01 and CAT01 as visible attributes to your fuse symbol.  As Bob Hanrahan explained earlier in this thread, key into the TEXTVALUE field in the Catalog Database record for each part the text string to enter the manufacturer name into the value of the MFG01 attribute followed by a semicolon and the part number into the value of the CAT01 attribute.  For example, MFG01=Bussman;CAT01=BC6031B.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in AutoCAD Electrical training and implementation support
Phone and Web-based Support Plans Available
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please Accept as Solution if I helped you. Likes are also much appreciated.
Message 29 of 30
rhesusminus
I'd really like for you to have a look at what the "dark side" offers @james_moore
Let's do a short Teams-meeting some day!
I totally get what you mean with the time and efforts you have invested, but aren't you just a little curious about what the red pill tastes like? Or maybe scared 😉 ?
Trond Hasse Lie
Ctrl Alt El
Message 30 of 30
All replies have been turned off by the moderation team as the conversation is no longer constructive and an answer has been given and accepted.
Thanks for being a part of the community!
Technology Administrators
AutoCAD Beta
