From Spreadsheet function Column labels not found
lauren_manuel4MPDR
Observer Observer
lauren_manuel4MPDR
Observer
Observer
I am trying to import loop drawing information from an excel file into a loop sheet template I created.
I get the AutoCAD Message: Column labels "HDL" and "Filename" not found in the file. Unable to continue after trying to import.
The columns I have are for each of the attributes I created. Files are attached.
rhesusminus
This seems like some custom stuff that someone has programmed. It will not work with AutoCAD Electrical.
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
lauren_manuel4MPDR
Observer
Observer
Is there a way to take an excel file and use that to automatically populate the loop sheet?
rhesusminus
Yes, using some custom programming. If this used to work, someone has already done this.
Trond Hasse Lie
Ctrl Alt El
