I am creating my panel footprint BoM but even the footprints I have deleted are showing in the BoM, How can I fix it?
Please run AEREBUILDDB to refresh the database and try to run the BOM and check.
Jaya Priya Ramasamy
Senior QA Analyst
www.autodesk.com
Hi Jaya! A few years ago we had a similar issue with exporting to a spreadsheet. The data was not up to date/time. I requested a fix. Autodesk added code to force a database rebuild prior to exporting to a spreadsheet. I think it’s time to add the same code sequence for creating a BOM.
I remind my students to run AEREBUILDDB before creating any report, but they shouldn’t need to. And ever since the Ribbon menu was introduced, Autodesk removed the AERBEUILDDB icon from the menu. I show my students how to add it back, but not everyone takes my training course. I requested that the AEREBUILDDB icon be added to the ribbon years ago. I posted it to the Idea Station. I even showed where to place the icon.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor
Specializing in AutoCAD Electrical Implementation Support
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Thank you for pointing it out. Let me check and discuss with my team.
Jaya Priya Ramasamy
Senior QA Analyst
www.autodesk.com
In a worst case scenario, close AutoCAD Electrical and delete the project scratch database file from your User folder. It will be <projectname>.mdb. Then restart AutoCAD Electrical.
Doug McAlexander
Hi @la_mubeenkaleem ,
Is it possible to share the dataset to us for trying?
You can send to my email address: jaya.priya.ramasamy@autodesk.com
Jaya Priya Ramasamy
Senior QA Analyst
www.autodesk.com
