What am I likely doing wrong to make FILEDIA get set to zero. I realize it has occurred every time I do SAVE AS on the toolbar and can't find the pop-up. I then set FILEDIA back as a one. Then a while later SAVE AS does not do a popup window again so I have to set it again. I am mostly working on symbol builder blocks right now and have no add-ons running with AutoCAD Electrical.
Solved by rhesusminus. Go to Solution.
Solved by Icemanau. Go to Solution.
Solved by jseefdrumr. Go to Solution.
Check the settings in SYSVARMONITOR.
It's the system variable monitor. Open it up, and look at the status of FILEDIA.
It sounds like SYSVARMONITOR might be set to keep FILEDIA at '0' when it should keep it at '1'.
Preferred value is one. Why do we need a preferred value? Is this reset to something different each time we create a new drawing or project? I assumed it is a program setting that affects all projects until changed to something different.
Well, if the preferred value for FILEDIA is already 1, then that's normal.
It's hard to say how your FILEDIA is getting flipped to 0 without your knowledge. Possible suspects include external LISP commands and other custom code.
However, whenever a system variable is changed, AND if that variable is currently in SYSVARMONITOR, then you will see an entry on the command line when it happens. It will say something along the lines of "system variable FILEDIA has been changed from its preferred value of 1". It's not super-obvious, though, and if it happens in the middle of something it can be hard to spot.
That's about the only thing I can think of that will help you figure out how this is happening.
Thanks for your help. I did set it to alert me so maybe I will catch it next time. If nothing else I am now starting to memorize the command to check it (it has occurred three times). I am not aware of anything custom that I am doing (or anything in the projects that might trigger it).
Some commands change settings like FILEDIA and then when they finish change them back to the default value.
However, if the command ends unexpectantly, then it may not get changed back.
Try not to ESC out of commands and letting them finish normally is the best bet.
Regards Brad
Brad Coleman, Electrical Draftsman
Bingo! I think you just solved it. I was aborting the symbol editor process because I kept getting the "Insertion Point Not In Line With Wire Connection" Error/Warning. I was afraid to let it save with an error so I aborted and made it worse for myself. lol. At least I learned something.
I ignore the "Insertion Point Not In Line With Wire Connection" warning. It's sort of valid for schematics, but not really. AutoCAD thinks the wire connection point needs to be in line with the main grip of the object. Depending on how you use your schematics and footprints, that may or may not be true.
I had the same issue occur today for CONTACT attribute. The audit said the attribute was missing, but it was not used for a vertical symbol that I was creating. It works fine.
I have noticed that the "Not in line with wire connections" error disappears on mine when I edit the symbol later to do any small adjustment of any part of the symbol.
The symbol audit feature should really be used as a way to see what problems might exist. From there, it's up to us to decide whether or not the 'error' is actually an error, just an oversight, or something totally unnecessary. I don't even use it. If you use the Symbol Builder tool along with the proper attribute templates, you'll almost never build a symbol that doesn't work.
Since I have been upgrading a lot of older standard AutoCAD WBlock files to symbols, I find it handy to confirm that I didn't accidentally miss an attribute.
Yes and this is a perfect use of the Symbol Builder. I imagine it's saving you a lot of time in that regard.
I've always been on the fence about this tool. Sometimes it causes more issues than it solves. I'm at the point now where I can build any (non-paramteric) ACADE symbol I need from scratch without it, just by being familiar with how the symbols work. The only time I use Symbol Builder is if I know in advance that I need lots of pins in my symbol, then it's handy to have the feature where you just poop out one after another and ACADE automatically increments their values. Otherwise, I leave it alone.
In Version 2022, every time I open AutoCad it resets to 0. I am not loading any lisp routines.
It's just a "feeling", but I had that same problem in 2022 myself. I couldn't pinpoint it, but it happend too often.
So, I edited this line in my wd.env file:
WD_OPEN_DWG,(SETVAR "FILEDIA" 1),AutoLISP prog or expression to autoexecute when dwg opened from PROJ dlg
Now, AcadE sets the FILEDIA variable back to 1 each time I open a new sheet. Haven't experienced the problem since.
@matthewcontrols написал (-а):In Version 2022, every time I open AutoCad it resets to 0. I am not loading any lisp routines.
1. Check autoloading lisp in the AutoCAD settings
2. Reset all settings.
3. Recently, I have been receiving files from users in which the settings of system variables have been changed and they break my AutoCAD. I think you had such files.
@rhesusminus написал (-а):Now, AcadE sets the FILEDIA variable back to 1 each time I open a new sheet. Haven't experienced the problem since.
It is not right.
The system should work automatically.
Many Lisp and programs set 0 to open and work with the file. You will have problems later on.
I'm not sure how experienced you are with AutoCAD Electrical, but this is a well known issue with AutoCAD Electrical, mostly due to all the scripts it generates and run on the fly, to update this and that.
It feels like it's just gotten worse.
Yes, it SHOULD work automatically, but it doesn't.
Is there a trick on 2022 version with regard to FILEDIA value? I am having to reset mine to one almost every time I open a drawing through the menu. I guess I need to make an SCR file to put it back to value of one and just click it randomly.
I feel like I am going backwards with this version other than the Floating Window feature (which is very nice).
Did you try to edit the wd.env file as suggested above?
