Error in drawing file when opening after converting from DXF to DWG
Hi, I use a DXF template based software to generate drawings. After converting the filled in template from DXF to DWG for ease of access, the drawing will bring up a dialog box that says "one error was found in the drawing file during open would you like to cancel" etc. etc. and that I should run RECOVER on the drawing. This breaks my workflow with Multibatch and I would like to get to the root of the problem. The Lisp routine I run to convert the DXFs goes
_qsave
_redraw
