Error 25001, Unzip error: Failed to open the ZIP file
joehiti
Message 1 of 11
joehiti
I'm trying to install the IEC-60617 library but keep getting this message. How can I solve ?
Replies (10)
Message 2 of 11
rhesusminus
Well... Do that file actually exist?
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Autodesk Expert Elite Alumni
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
Message 3 of 11
I have the same problem with the IEC-60617 Library. How i can resolve this ? Thank you.
Message 4 of 11
rhesusminus
Same question to you...
Trond Hasse Lie
Ctrl Alt El
Message 5 of 11
Same problem. No it does not exist. Where do I get it? Also, why is it not already there? I thought I did a full install. I'm just trying to get a symbol for a 3 phase motor from the icon menu....
Message 6 of 11
rhesusminus
Did you do a browser download when you installed AcadE?
If not, I'd do an uninstall, re-download, and reinstall.
Trond Hasse Lie
Ctrl Alt El
Message 7 of 11
Same problem repeat
Message 8 of 11
rhesusminus
And, if you have a look at me questions/suggestions, will they help you solve it?
Trond Hasse Lie
Ctrl Alt El
Message 9 of 11
I had the same problem. Here is the cause and the solution for me:
The cause of the problem is: the first letter of the filepath. The disk from wich you installed the program now has a different name(=letter) or has been removed, so the installation wizard can't find the files, although they exist. You installed it form disk I:\....(whatever letter the filepath in the error says) so it's looking there for the installation files.
The solution is: mount again the disk that had the installation files in it, and change manually the name of the disk (like seen in this video https://www.youtube.com/watch?v=nBDjHidZLLY) to match the letter that is in the error message.
Works like a charm.
Install/unistall does not fix this, if the installation file is let's say in an external disk that may have a different name every time you mount it.
Message 10 of 11
Thanks!
Message 11 of 11
Solved: I moved the installation file  to C and Started a new installing and it solved
