AutoCAD Electrical Forum
EMBEDED HIGH RESOLUTION IMAGES
2 REPLIES 2
NateWa
422 Views, 2 Replies
We have a current discussion on how to embed a high resolution image into AutoCAD. I have access to AutoCAD Electrical 2016, and AutoCAD 2018. but we have multiple disciplines that embed photos into drawings. The problem we are having is while zooming in on the photo, at some point it just goes black. I would post the example picture I was given to test this but it has people in it so I don't think I can. however I will attach snapshots of the photos properties.
2 REPLIES 2
jseefdrumr
in reply to: NateWa
If you're referring to the image's behavior in ACADE, then this is most likely normal. For any OLE or embedded object like this, there comes a point where resolution cannot be maintained while zooming in. Remember, you are trying to view a raster object in vector-graphics software. While you may be able to change the point at which resolution is lost (i.e., that point where ACADE quits trying to process the image and just makes it black), I don't think it's likely that you'll avoid this entirely.
Now, if you're talking about the plotted output only, that's different -- but would require some more background info in order to try and fix.
Hope this helps,
Jim
Jim Seefeldt
Electrical Engineering Technician
NateWa
in reply to: jseefdrumr
Jim,
Thanks for the information! Yes I was referring to the images behavior, and I'm glad I finally have an answer.
