When using the export to Inventor tool for the import harness data tool in Inventor, all the terminal rails are brought in as one single part, because of this, you cannot assign the individual terminals and/or their pins.
Please, can you change the tool so that either the terminal come into the harness data as individual parts or possible allow you to select sub-assemblies in the main assembly to assign a sub-assembly as a rail?
You can see that the Electromechanical link file sees the terminals as they should be (as individual parts) and allows you to place them individually.
I have noticed that it works fine when you carry out the export using the 'Active Project' option..... therefore maybe only the tool needs improving so that the 'Project' options works the same.
ACADE & PLANT3D Applications Engineer
Standard and bespoke PLANT3D Training and ACAD Training and ACAD ELEC Training
