AutoCAD Electrical Forum
Editable revision triangle
4 REPLIES 4
snorcisa7FS8E
7391 Views, 4 Replies
I'd like to create a editable revision triangle to be selected from the icon menu or something similar, but that can be shared with other users. I've tried making it a block and editing the icon menu to be able to select it from there
but when it comes in it's not editable unless you explode it. Is there an easy way I'm not thinking of?
4 REPLIES 4
OP21
in reply to: snorcisa7FS8E
Just add an attribute to the revision block. During the block creation phase you can select the check box parameter of the attribute to "verify", this way each time you insert the block it will prompt you for the value or you can predefine a default value and change it during the insertion.
Hope this helps!
Omar
P.S. If this did help you, remember to "Accept as Solution", so the answer can help others. "LIKES" are always welcomed and much appreciated! Thank-you.
snorcisa7FS8E
in reply to: OP21
The weird thing is that some sheets of the schematic are at different revision levels than others. Would this attribute be reading from the title block attribute on the ,wdt file or from what's actually in the title block of the sheet it's inserted into? Because they will be different.
OP21
This would a manual entry each time the revision triangle is added to the drawing.
Hope this helps!
Omar
snorcisa7FS8E
in reply to: OP21
Aaaahhhh!
That sounds just like what I'm looking for.
TY!
