I tried doing some searching, but found no real answer. I was wondering if it is possible to create custom attributes which has it's value based dynamically from other values. I'll give an example:
In some of our blocks, I'd like to be able to have the Installation and Location on the same line. Can I create an attribute, lets call it "INST_LOC" and have it dynamically equal to the concatenation of the component's Installation and Location, with a space between them? This would help save some space and if this is possible, it opens the door for new possibilities.
I took a look at the Help file for the WD_M block, and I assume you mean the IEC_INST and IEC_LOC fields?
I'm not quite sure how to insert them into an attribute though. When I type the "Field" command, I do not get anything hinting at project values.
I tried creating a custom attribute where its value was "%I %L", but all I got in return was the literal string. Also, the way our drawings are set up might now conform to this. I may have multiple components on schematic for say, a breaker, that has multiple trip contacts on the control drawing. Some contacts may be from Panel 7, while others may be from Panel 3 or any other panel.
Yes, that is what I was trying to achieve, so that I would be able to show Installation and Location on the same line without having to manually edit each one to move the attributes around.
