Drawing Spreadsheet to Excel File
Arlene_Brown
Message 1 of 11
Arlene_Brown
Hi there,
I have been tasked with setting up a report that automatically outputs attribute data from my drawings to an excel spreadsheet which is then used to upload to out order management system to automatically create part numbers and all the associated attributes. A separate spreadsheet will also be created from ACADE to again upload to our order management system to automatically create the BOM for each contract. The idea of this exercise is to standardise and automate the process more thus reducing overall time spent on loading parts and creating BOMs on each contract. However I do know how to create reports for outputting the attribute data on the drawings onto a spreadsheet. However the spreadsheets need to carry a specific format for loading onto our order management system. Is it possible set up a report that outputs specific attribute data on the drawings to a spreadsheet that already exists in a specific location??? In otherwords I don't want ACADE electrical creating a new spreadsheet each time I run the report as it need to be a specific spreadsheet. Can anyone advise me on how this can be done?
Thanks in advance for you help.
Replies (10)
Message 2 of 11
dougmcalexander
I teach my clients to use the Automatic Reports option to produce wire list, BOM, wire label report, etc., so they can produce all necessary reports quickly, perhaps while they grab a refill of coffee.
You can create a report format file, using the Report Format Setup utility, that can output a table to drawings that get added to the end of the project, while simultaneously creating a report that is output to a specific file (i.e. spreadsheet).  This can be a spreadsheet that everyone shares on a network drive or it can be a user-specific spreadsheet that is output to a folder on the local drive.  In the case of the latter, I advise my clients to create a folder on their C drive named AcadE Reports.  Set the path to this folder, and filename, while defining the Save to File option in the Report Format Setup.  Once the report is created you can copy it to your project folder or wherever you need to place it.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor
Specializing in AutoCAD Electrical Implementation Support
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Message 3 of 11
Arlene_Brown
Thank you for your reply Doug.
I do have similar reports set up. However my issue here is that the spreadsheet in which I need populate already exists and needs to carry a specific format for uploading to our order management system. Is it possible to store this spreadsheet locally and set up an automatic report to populate specific fields of the spreadsheet?
Thanks again.
Message 4 of 11
rhesusminus
You might need to do some programming. When you run a report to file, you're asked if you want to run a script.
Here, you can create a macro/script that takes the output from the report, and manipulate it anyway you want. Like putting the data into specific field into a specific document at a specific location.
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Autodesk Expert Elite Alumni
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
Message 5 of 11
Arlene_Brown
Thank you.
Do you have any examples of scripts that I can use?
Message 6 of 11
rhesusminus
No, unfortunately not.
Trond Hasse Lie
Ctrl Alt El
Message 7 of 11
Arlene_Brown
Ok thank you.
Message 8 of 11
ccad2509
You mean like this choose your report
specify the template file and target file
select your attributes
add markers in your template file
generate your report
all out of the box pity its not ACADE
Message 9 of 11
Arlene_Brown
Oh great. This looks promising. I will give it a try and let you know how I get on.
Thank you so much.
Message 10 of 11
ccad2509
sorry Arlene that's not ACADE
its me having a dig at president for life Doug
who has over the years made a big issue on how flexible and good ACADE is but goes very quite when he cant sell you training or a solution
when another product does what people want in this forum out of the box without investing in custom coding there is also a deafening silence from president Doug
Message 11 of 11
Arlene_Brown
Yeah I guessed that as I tried searching for the command and couldn't find it.
