- Mute
- Permalink
- Report
It looks like there is a known issue but when I add drawings to a project the drawing descriptions disappear (not other fields though as shown in screen shot). I found this explained on a few different forum posts but the most recent I found was 2013. Regardless, I can remove a drawing from a project, then add the same drawing and the descriptions will be gone. I don't move the drawing or anything. Is there not a fix for this? I am using 2018.1 so figured it would be good if there was a fix.
The reason this is a larger issue for us is we are adding a Master project with all drawings in multiple different panels (each panel has it's own project) but when we add them to any project the disappear. Is that still just an issue we have to know about? I know we can use Export/Import but I am searching for more of an explanation as well as a fix if there is one.
Thank you.
