I made a mistake by deleting the DOT symbol and now trying to hunt down the file name iec60617(shdot). Can someone please tell me how do I get that default image/icon back on to the Icon Menu? Yes I did went to the link below, but can't find it. Thank you
Users\username\AppData\Roaming\Autodesk\AutoCAD Electrical {version}\{release}\{country code}\Support\
Solved by swhiteford9J8W8. Go to Solution.
Solved by rhesusminus. Go to Solution.
You're looking for iec60617.dll
That is the file with the icons.
(Shdot) is the name of the resource/image within that dll file.
The Icon Menu supports four types of icons.
1. SLD file (use MSLIDE command to create one)
2. PNG file (use whatever IMAGE editing program you want to edit it)
3. Resource files (DLL) with many PNG images in it.
4. SLB (Slide library). It's only used by some old functionality (lisp and dcl-dialogs). Like the images used in some dialogs, like Drawing Properties -> Styles:
For number 3 and 4, you cannot "browse" to the correct image. You need to type the format:
resourcefile(resourcename)
To generate the DLL file, you need Visual Studio or the like. The SLB file is compiled on the Windows Command Line with SLD-files (Don't ask).
The location for the the DLL/SLB files is
C:\Users\KT\AppData\Roaming\Autodesk\AutoCAD Electrical 2023\R24.2\enu\Support
For PNG/SLD it is:
C:\Users\KT\AppData\Roaming\Autodesk\AutoCAD Electrical 2023\R24.2\enu\Support\IMAGES
It's a known issue if you change the WD_SLB setting in WD.ENV, that it messes up those paths. It was reported 8-9 years ago. Nothing has happened since.
