Hi, I am using a Mersen FSPDB3A Finger Safe Distribution block to provide 242VDC to a group of breakers.
I used "terminals without wire changes" on my schematics, calling out each pole as a "Pin". My issue is I can't figure out how to create a panel symbol and link it to the terminal for my panel layout.
Solved by iewnhoff. Go to Solution.
I have used a couple of different approaches for this scenario over the years. I will describe the easier method below:
I assign the part number to the first terminal symbol I insert. In the case of the PDB that I use, this is terminal 0 (zero), for example X1:0. Each subsequent terminal that I assign to strip X1 will be assigned numbers 1 through 11. My PDB has one input, lug 0 (zero) and 11 outputs, lugs 1 through 11. The part number, which was only assigned to the first terminal (X1:0) is linked to a footprint that represents the PDB by making an entry into the Footprint Lookup database. Insert the footprint using the Insert Terminal (Schematic List) utility, as shown in the attached screen capture.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor
Specializing in AutoCAD Electrical Implementation Support
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Thank you. I was doing all the same steps except for the insert terminal last step. That did the trick!
