AutoCAD Electrical Forum
Design Terminal footprint
1 REPLY 1
darok8
220 Views, 1 Reply
Hello, in my projects I use the Wago terminals, but the graphic representation of the Wago terminals is very flat, in fact they don't look like terminals, I don't like how they look in the projects, because of this, it is chosen to use Wago smart designer and generate the rail in 3d and then pass it to autocad, and by hand place the numbering of each terminal, my question is, is it possible to generate my own footprint of the terminals that I use and be able to only work in the Autocad Electrical editor, I show how they look in autocad and how they look in Wago smart designer....
1 REPLY 1
yes, you can draw whatever you want for the footprint.
i found the following useful for the attributes that should be included
https://blog.hagerman.com/2014/02/04/multi-pole-multi-level-terminal-blocks/
you then have to assign the file to the catalogue number in the footprint lookup database
Technology Administrators
AutoCAD Beta
