Delete Multiple Components
yan_ken
yan_ken
Hi there,
On AE schematic, I know it's is best practice to right click and click delete an component, but how do I do the AE delete component function for multiple components?
Should I just use conventional delete multiple components and do a AEREBUILDDB?
Hi Yan
You are correct, however you can select the "delete component" command from the Ribbon bar first and then do a window select of all the components on the drawingsheet.  This will ensure that all the components are deleted from the database all the wire gaps will be closed. 🙂
Hope this helps
Best regards
Marc
yan_ken
Thanks Marc.
I can't believe I missed that icon...
No Problem at all,  pleased it worked !!
shuhwat
Community Visitor
Community Visitor
Not working. First i selected the the delete icon and i press the left mouse button no selection  occurs
rhesusminus
Any error message on the command line?
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
nathan.averett
After clicking the icon, type 'W' and press enter to enable the window selection.
