Default path in the icon menu wizard
I want to change the path of the icon menu to my custom file, But the default path is set to ACE_NFPA_MENU.DAT, and I'm not able to change it
Where can we change the default path
ramesh.kambang
Add a line or modify the Menu & Slide path in wd.env per marked in RED, eg my .dat file is in D drive. Then click default in the project properties
Ramesh Kambang
Aerospace System/Design Engineer and eVTOL/EWIS Expert
EASA 21J, UK 21J, MAA DAOS, Certification Specification CS23-29, CS-ANCS, CS-STAN and EVTOL
Please select "Accept Solution" if this post answers your question.
It was helpful, thankyou for your reply
