Default field value
Default field value
galashkina
Advisor Advisor
Message 1 of 11
Default field value
galashkina
“Delimiter between multiple instances on same line of text” field must have a value of " " (space) by default.
How to do it?
In which file is the value of this field set by default?
Thanks!
Replies (10)
Message 2 of 11
rhesusminus
I don't believe it's saved in any file, but using this line of code, you can set the default parameters.
You can do this in the WD.ENV or acaddoc.lsp  also, to make it be the defaults on each start of AutoCAD Electrical.
(setq GBL_WD_PNLW_FORMAT (LIST "%T=%W (%2)" "%W (%2)" 0 -1 1 " "))
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Autodesk Expert Elite Alumni
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
Message 3 of 11
galashkina
I created the file acaddoc.lsp and added a line (setq GBL_WD_PNLW_FORMAT (LIST "%T=%W (%2)" "%W (%2)" 0 -1 1 " "))
I added acaddoc.lsp to the list of applications.
It's enough?
But the default field value has not changed Smiley Sad
Message 4 of 11
rhesusminus
If you paste it to the command line, will it work then?
Trond Hasse Lie
Ctrl Alt El
Message 5 of 11
galashkina
Yes, it works
How to start the program automatically?
Message 6 of 11
rhesusminus
I'm just on my phone right now.
If the file acaddoc.lsp is found in the AutoCAD search path, it will be loaded automatically when AutoCAD start a New/open a document.
I'll look into how to put it into wd.env when I get back to my computer.
Trond Hasse Lie
Ctrl Alt El
Message 7 of 11
galashkina
Оk,  I'll wait
Message 8 of 11
jseefdrumr
This might seem like a silly question, but I catch myself skipping the obvious stuff all the time...
Did you restart ACADE after adding it to the startup suite?
Jim
Jim Seefeldt
Electrical Engineering Technician
Message 9 of 11
galashkina
Yes of course
Message 10 of 11
jseefdrumr
Thought so, but I thought I'd check while you wait on Trond.
Jim Seefeldt
Message 11 of 11
rhesusminus
I did some checking, and AcadE is doing som initialization/resetting of variables, making the scahnges in the lsp/env file not stick.
The quickest workaround I found was to change the macro of the Wire Annotation button using the CUI command. This is the new macro:
^C^C^PWD_1;(setq GBL_wd_pnlw_format '("%T=%W (%2)" "%W (%2)" 0 -1 1 " "));_AEWIREANNOTATION
Trond Hasse Lie
Ctrl Alt El
