Default Dot Tee Marker
Every time i get a new node in my drawing, it gets marked with a angle tee but i want it to be a dot tee. Can i set the Dot Tee Marker as default?
testsubject
There are two places that you need to check:
Project Properties and Drawing Properties.
The information is located on the same tab in each: Styles.
If you look in the lower left hand section you will see a box labeled "Wiring Style." This is where you set the type of "Tee" you want.
This can be done a Project wide or per Drawing basis.
Bob Hanrahan
Ace User since 1998
Autodesk Expert Elite Alumni
If this answered your question, please click on "Accept Solution"
