Customizing Automatic Material List with Parent and Child References
bala676
bala676
I am trying to Generate Bill of Materials for the projects, the out put of the reports only shows the CAT information, LOC, QTY etc.. But i wish to see the Parent Child References in Block, i already created a sample block, but i am not sure, where i need to add to get the output report in block format.
I am here attached the screenshot of the sample block, i wish to get the output in this format. Could you please check and guide me.
ramesh.kambang
When you run Component BOM report, make sure you check mark "include children for above".
Ramesh Kambang
Aerospace System/Design Engineer and eVTOL/EWIS Expert
EASA 21J, UK 21J, MAA DAOS, Certification Specification CS23-29, CS-ANCS, CS-STAN and EVTOL
Please select "Accept Solution" if this post answers your question.
bala676
I wish to have the Component list in the attached Screenshot format. May i know, what i need to do ?
I can get only the reports in standard table style...
rhesusminus
There's no way to get the symbol graphics into the report in AutoCAD Electrical using standard features.
I guess you can achieve it using custom code.
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Autodesk Expert Elite Alumni
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
bala676
Yes i too think of that. Could you advise me, how i could achieve that using custom code. My existing project have this graphic symbol in BOM Report.
It looks good and more clear for the client to understand. Also while generate Component report, after i select "Child for above" still i could not get child ref in my standard report format.
Please provide your expertise for the above two issues.
rhesusminus
No I can not. There's no way to easily explain this. Learn to program, learn the AutoCAD Electrical API. Or pay someone to do this for you.
The reports in AcadE will only report the cross-reference to the parent component. Always.
Again, this can also be fixed with custom code.
Trond Hasse Lie
Ctrl Alt El
bala676
Yes i understood, i will consult with Experts who customize the Autocad.
Thanks for your kind reply.
