My goal is to have a child component behave similar to a PLC I/O component.
I am sure many of you know that the PLC I/O Module can automatically populate the wire numbers going into the I/O module with %F%S%N and "search for PLC I/O address on insert" checked under drawing properties.
I am hoping to make a child component behave the same way. Unfortunately the wire numbering behavior is different. I suspect this to be due to some kind of missing tag or link. In this case I used F%FF S%SS N%NN to show the breakdown of how ACADE is reading this. Has anybody encountered this before? Is there a solution?
I attached the parent and child component I am using in case someone wants to test out my setup.
I appreciate the feedback.
Solved by rhesusminus. Go to Solution.
The block names are completely off. They should start with PLCIO.
The child TAG-attribute must be "TAG2", not "TAG1". That might be the problem (Haven't looked at the files yet)
