Apparently out of the box ACADE recognizes if 2 schematic symbols have the same tag number they are the same components but that is causing some of our large clients a little issue. I am wondering if there is a way for components to also look at the location code.
Example would be we separate the panel names by process. Lets say Process 1 and Process 2. so I would have a panel in Process 1 starting with P1-E1 and panel in Process 2 as P2-E1. These are both sheet number 1 and occasionally we have the same component on the same sheet in different panels. Maybe ethernet switch, so sheet 5 in the same place it would be tagged the same. Sometimes even years later we do a project that will need both of these panels in 1 project, we update 1 it wants to update the other even though the location codes are different (P1 and P2).
Can someone let me know of a way this is possible?
Thank you.
