Component tag replaceable parameter issue
dmytro_rozhkovych
dmytro_rozhkovych
Hello. I have PLC IO electrical symbol which when inserted will automatically assign sequential address based on certain rule. Namely as far as I can see, in the attribute property for default value "%%A+2" was added, for next IO address tag default value "%%A+4" was added, and so on. I did the same modification to the different block from the same family, however when I inserting it, I got the message that "Not all address values were resequenced" and it doesn't automatically assigns IO addresses.  Both blocks I am inserting into the same drawings just to eliminate issue with drawing properties being different, one original block is working and modified does not. I attached both blocks.  Please advice.
dmytro_rozhkovych
Found solution. All it needed to restart AutoCAD.
