component pin with 2 wire number
I am trying to create a symbol in which one of its connection pins can have two wire number, there is a way to do it?
Put 2 Wire Connections really close together but enough that you can tell them apart? putting 2 wires in the same wire connection on a component is the same as connecting the 2 wires and ACADE sees it as such. So you are trying to say one branch of a wire is one number and another branch is a different number?
i make the component 001-DPAC-INPUT.DWG , it have two terms (TERM01 and TERM02) each one whit 3 pin conections (XnTERM01 or XnTERM02), but i need that for example that wire number in X1TERM02  be different of wire number in X08TERM02.
This thing is Big! And yeah that works... I had to redo the wire connections but otherwise it was fine, I was able to put 3 wires and wire numbers on each one.
